J
jason808
Guest
I just finished installing a furuno autopilot in my 208. I used a reversible piston adjustable octopus pump. The pump is nice because it has a shutoff valve as part of the pump and the flow is adjustable.
I bought the octopus kit
Octopus 30" Hose & Fitting Kit Including Orb & NPT Helm Fittings
I was not able to use the tees from the kit because I did not have room behind the helm. The hoses in the kit are only 30” which really limits where you can put the pump.
I ended up installing mine exposed in the cabin but would have been nicer to install it under the seat in the cabin. If I did it again, I would have chosen a location for the pump and ordered custom length hoses.
Here are pictures of my finished installation in case it helps. It also shows barely any room behind the helm because the electrical wires.
To purge the hydraulic lines I used this kit
outboardst.com
It made getting the bubbles out really easy and a one person job. There are cheaper ways, but this made it nice and simple.
Bubble Purge™ G2 Hydraulic Steering Bleed and Purge Kit OST-PBB.001
In Stock! We created the Bubble Purge G2 to offer you an easy to use tool that makes hydraulic steering maintenance and repair a 1 person job. Our patented kit is a perfect fit for SeaStar, BaySta…
