- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
I recently shattered a glass vent window on my 265....long story...I'll spare you...
Luckily, all hardware remained onboard.
I replaced glass with acrylic sheet .220"x24"x18" from home depot.
Project went crazy easy...
I used the other window to trace the pattern with a sharpie. Marked the holes.
Used a 5 1/2"' 100 tooth circular saw..."took the line"
Sanded the edges.
Drilled the holes. (be careful. a bit will grab when it pushes thru) Drill from both sides to make clean hole and avoid problems.
Used a countersink bit to knock off edges.
Lightly glued into hinge piece using 5200. Its what I had laying around. I would suggest something else because the white can be seen thru the clear window.
I used some black liquid neoprene on the hinge which should keep it from rattling.
Sanded the edges.
