- Mar 13, 2013
- Atlanta / Carrabelle, FL
- Express 330
I have been fighting reoccurring water leaks in the cabin from the bases of the forward stainless supports for the hardtop & was wondering if it is a common problem or something unique to my boat. It seems to be more of a problem with the two inner supports versus the two outer supports.
I have been using 4200 to seal the contact points and the bolts that secure the bases. The fix only seems to last about six months and then the bases seem to loosen up again. Until I figured out where the water was getting in, I had to keep towels under the starboard cushions of the mid berth as that was where the water seemed to accumulate. Now I have small towels stuffed into the access ports for the bolts - last time down they were quite wet, so it looks like it is time to fix it again.
If any of you have found a long term solution to this problem I certainly would appreciate hearing from you. Thanks in advance.
