- Oct 16, 2007
- Age
- 70
- Cape May, NJ
- Islander
Spreader lights are controlled by the switch in the dome over the helm. These switches are notorious for failing. It should be a 10-amp version that I'll list below.
What I would do is open up the spreader lights and ohm out the wires to the dome light. Make sure that you have a solid ground to the spreader lights. I'm not sure if that ground wire runs to the dome light or back to the fuse block (could be your problem).
The other thing I would do is switch to LED spreader lights. Less amperage draw and better light.
On my 1997 268 Islander there are two switches on the dome light. The dome light switch Off - dome light WHITE on - off - dome light RED on. The other switch is for the spreader lights Off - On.
The spreader light switch frequently burns up under the load of regular spreader lights. Higher amperage switches are available from Digit-Key. I would suggest going to LED spreader lights too.
My spreader light switch went out too. I found them at DigiKey.com - great price - order a couple of them for spares. Same vendor part that OEM used.
512PB-ND $1.94 Spreader light switch (SPST 10 amp)
522PB-ND $2.52 Dome light switch (SPDT 2 amp) << Digit-Key shows this as a $12.00 part now.
