Bob Coco
I just sold my 282 Sailfish but kept my Venture trailer for my new 283 Release. Now my trailer is a galvinized tripple axle. Just looking at your setup and my thoughts are the same as some others posted. Shift the boat back enough to get the winch post relocated back the mininum distance needed to get it past the outside rails but no further then needed. Then you will need to get the bunks further back and probably slide the axles back a bit too.
I had the opposite problem with my trailer. I had negitive tongue weight when I first got my trailer. I had to keep moving the boat forward. I still have very little tongue weight. I think that is because I have a third axle to help support the load. I can raise my jack and the tongue will not go to the ground. I think you just need to be at a ramp when there's no other boats using it with a set of sockets and some wrenches. I actually used a 1/2" drive battery impact gun which made the job of adjusting much easier. Another solution as someone had mentioned was to add another post. That would also work but I don't think it's needed.
The easiest solution is to keep the trailer and buy a longer boat. LOL Just kidding.
If you are leaving it as is for the winter I would support it further back with some blocks either under the keel or on either side of the trailer so that flex doesn't become a permenant part of your trailer.
Regards, Bob
Regards, Bob
