- May 6, 2015
- Misquamicut, RI & Melrose, CT.
- Freedom 255
Looking at the wiring diagram for my boat (with a single battery selector switch) it appears that they run a 50A protected 2ga. feed to the console that everything runs off of except the always hot bilge pumps. I will grab the power there and mount the breaker next to the up/down switch somewhere on the helm.journeyman said:I would find out how Grady wires a windlass on your boat. Should be able to see from the diagram in the owner's manual. If you don't run a dedicated line to the windlass motor, you could run the risk of disrupting power to your electronics and things. The control power to the windlass relays, OK. But not the motor itself.
