Windlass - opinions please
I agree with Ice. Taper them.
About 3 strands from the right, something looks out of place. Is it just the angle and the way it is showing in the picture?
Its not finished in the picture. and there is a piece of black tape in the middle
I couldn’t work out how to have the pic and the text hahah
My beast showing the winch, it’s massive but strong as a bull and the diameter pulls up the anchor in no time, also I have a sock over the chain and so it is silent going over the roller .... every 10m I have some blue cord spliced into the rope so I know how much I have out .... no water, sand or weed gets into my bilge from the winch anymore.....
WOW! I have never seen anything like that.
Looks like something they'd have in Louisiana...they always have weird sh....
journeyman
Gloucester, MA
Will these splices work on a windlass or will I have to taper them? 5 or 6 tucks each way
I consider myself a B- when it comes to splicing. Better with 3 strand, lots of back splices and loops but no anchor splices. Plaited line is a little trickier. Done some loops and one anchor splice which worked so, I guess, OK.
First, and I think you know this already, no loose ends. Stating the obvious.....
Second, there looks to be a hole there. Mis-tuck???
Third, that doesn't look like nylon. Lewmar specifies it. Is it Cotton?
I see your inner "Yankee Frugality" is showing but 3 strand nylon is CHEAP! Why not save yourself and buy what you want. No splices, no headaches.
A splice to be used in a windlass needs to be flexible. Too big and tight, it won't fit. Too loose and it will snag and fray. One trick is to splice it snug a few tucks then roll it in your palms to loosen/even it out. Tapering plait is easy. You are working with 4 pairs so you just cut, burn and drop one from each pair for a few tucks. I've never had to taper 3 strand, I guess you could halve each strand then cut, burn and drop for a few tucks.
It is nylon. just a few years old, some is limp so strands want to flatten out. the "hole" is a pice of black tape.
I did these splices with the idea of getting rid of really bad knots that were there. Wasn't thinking about eventual windlass.
If I get one I will have to redo them and taper. I am way to cheap to buy 800ft of line when I already have it....
I need to get a cutter for my soldering gun. That will make it neater.
I suppose a horizontal windlass will pass a splice better than a vertical since it only bends 90 degrees?
Gotcha.
Ozz... That drum is huge! You sure that's not supposed to be at the stern to pull in the fishing net? :)
Aesthetically, I don't think "it's for me", but it's interesting to see different ways of doing things. I do wish Grady would get with the times and start building the anchor locker as a separate compartment from the rest of the cabin so it can self drain directly overboard. I'm actually considering rebuilding the anchor locker so it does just that. Been thinking about it for 3 years now, though... other projects always seem to take priority.
Reactions: Ozz043
journeyman
Gloucester, MA
Just an opinion but if you're gonna possibly lay out 800' of line at times, the V700 is probably not the windlass you should consider. I've had 2 of them and they are good light to medium duty. Definately need something beefier! Another reason I use a retrieval ball.
Ozz's winch looks like a Mick, which is built down under.
http://www.mickswinch.com.au/winches/
Muir make a small one.
https://www.keoghsmarine.com.au/mui...wer-up-and-down-suits-most-5-8m-boats-f331002
They are more common than I would have thought, but I guess it makes sense for commercial boats. There is one that is pretty common here, in the larger cruiser category(retirees), that has a wider drum, but I didn't see it pictured.
https://www.google.com/search?client=firefox-a&rls=org.mozilla:en-US:eek:fficial&biw=818&bih=486&tbm=isch&sa=1&ei=HgtfXJqtH4K1_Abk2o3gDA&q=drum+anchor+winch&oq=drum+anchor&gs_l=img.1.0.0j0i5i30l2j0i8i30j0i24l6.15391.15391..18029...0.0..0.56.56.1......0....1..gws-wiz-img.cw-w10kqbDI
This is exactly what I do for fids. I have a box of various sizwd needles that I pick up in thrift shops for small change.
Reactions: Ozz043
I was looking at a pro fish on ebay but the bids went to high for taking a chance on a used one.
Anybody out there use just a capstan? There'd be no issues with line jams, splices, clutches,....still do the main job...saving our backs.... Looking at Maxwell Anchormax
I think the rope may start to pull off the top as you pulled it in, given the angle you would be pulling from would be quite a bit higher than it. Maybe not - but it seems like a possibility. If you bent over to do any pulling, it would put a strain on your back and be an awkward pull. Instead, just use the anchor roller like normal - but maybe step back further, or just sit on the cabin ceiling and brace a foot against the back edge of the anchor locker. That will at least allow for a straight line pull. Either way, you'd need a helper to drop the line into the locker to make this efficient.
Here's that Good windlass I mentioned.
http://www.clubsearay.com/index.php?threads/good-automatic-windlass.91178/
Ozz043
Glacier you’re spot on, it is a Micks winch.
Ugly as hell but it is perfect for the fishing we do here in South Australia...therefore a common site on most boats
joker
I'm considering adding a windlass to my 265 express. I have no experience with a windlass. Always had a smaller boat.
I've used a capstan on a destroyer but that doesn't help me here...
Looking at Lewmar ProFish 700, H700 or V700.
ProFish seems ideal with the FreeFall, H700 is same thing without freefall.
Both get bad reviews on West Marine site. Water intrusion, clutch won't release, never makes it thru a season without a problem.
V700 gets better reviews, assuming that because the motor is below deck. I like that. I like the look.
But no freefall available - you have to power the anchor down
the vertical also needs more drop into the anchor locker but I don't think that is a problem on the 265.
I know there are other brands but they seem to be twice the already too expensive price of a Lewmar. I know I can get it cheaper somewhere beside West Marine.
Assuming I get one, I imagine I might do better to add a dedicated Deep Cycle battery somewhere forward. My House bank is 2 Dual Purpose group 24s in parallel.
opinions please....
you have a lot of choices when it comes to a windlass. lots of great feedback for you the only thing I might add . At anchor always tie off your line on a cleat this will take the stress of the windlass
ocnslr
Fort Myers Beach, FL
We had a 60 degree day so I just spliced three old 200ft shots of 1/2" 3-strand. They had been tied together with "that'll work knots". I' got another 200ft never used so I won't be switching to 8 plait.
Sorry, but that is a "short splice", and it doubles the diameter of the line. It will almost surely jam in the windlass, even if tapered. You would need to make a "long splice", and your tucks would have to be very good as well.
https://www.riggingdoctor.com/life-aboard/2016/2/8/shortsplice-vs-longsplice
Reactions: SkunkBoat
another reason to just get a capstan I suppose. I don't see myself making long splices. :) Some say buy 1000' of unspliced line... $>(
But in reality, the first 200ft have no splice so any shallow water little day trip will be fine. When I'm out in 150' on a wreck we'll have someone up there who can keep splices clear of the gypsy if necessary.
fellinger
GOOD brand out of NJ is probably the best. I picked one up at the end of last season. Working on getting it on in the time for bottom fishing season. Run the power to a starting battery since you will be running the motors when pulling up anchor.
A short splice is no different, and no bulkier, that the thousands of back splices attaching rode to chain, and running through windlasses every day. Taper the short splice and it will work fine. Only use 2 or 3 sets of full tucks in the middle, and the taper that is already caught in the gypsy will pull it through, or over, unless you are trying to break an anchor loose, and putting a lot of strain on the rode, which is not the windlass’ job.
That is a piece of equipment.... Cool.
Halfhitch
Venice, Florida
Skunk, I am a believer in a capstan also. I installed one on a World Cat I had. It worked great and I like the fact that you can pull in any direction so when you eventually get that 400 lb. sword you can use it to bring him over the transom.(I want a picture)
The one I installed was an Anchormax and was this style https://www.wmjmarine.com/c14941.html and it had "spur cut" gears. It was noisy as hell but worked great. I wondered if the ones that have the motor set at 90 degrees to the capstan shaft are any quieter. If you could find one that used helical cut gears, that would be the bees knees.
