- Jun 30, 2008
- Ocean Pines, MD
- Express 330
Thought I’d double check to make sure I’m winterizing my Grady correctly and not missing anything. Boat is a Grady 272 with twin Yam 225's EFI's and here is what I do -
• Remove everything off boat (inc cushions around stern) and store inside.
• Empty Fresh Water system (inc hot water tank) and add several gallons of Pink nontoxic Antifreeze. Run through all outlets including the windshield wiper. (easy to forget).
• Pump out holding tank and add antifreeze. (is there anything I can add to keep the unit from ceasing up?)
• Change lower unit oil (something I did in the Spring). Can this wait till then?
• Add fuel stabilizer (tanks are kept full). I use about two of the Ethanol Sta-Bill 32 oz for roughly 200 gallons. Know it probably is more than needed but what the heck – it says more won’t hurt.
• Remove spark plugs and fog both engines. Crank engines quickly a few times and then replace plugs. New plugs go in after I run in the Spring.
• Spray engine with CRC but not around the o2 sensor. (Will clean o2 sensor and VST filters in spring after running a bit).
• Remove props and grease fittings and store inside.
• Clean & wax everything.
Boat is kept on lift during winter months. Am I missing anything?
Thanks,
Thanks,
