- Oct 16, 2007
- Age
- 70
- Cape May, NJ
- Islander
Did they give you a part number on this? while trying to remove the nut that holds the wiper assembly on, the bolt broke. Wasn’t much pressure at all. I need to order everything that is on the outside of the boatPulling up an old thread. This is the piece that broke on my wipers. After a bit of research, I found out the the company who was making the wipers for the 265 was sold to another company. Gave them a call and were very helpful.
https://www.globalproducts.llc/
He had me measure the arm. Mine measured 22" from the center of each pivot point. The part # he gave me for the arm was LE72113922S. He mentioned they had 24 in stock, but was now obsolete.Did they give you a part number on this? while trying to remove the nut that holds the wiper assembly on, the bolt broke. Wasn’t much pressure at all. I need to order everything that is on the outside of the boat
Thank you!He had me measure the arm. Mine measured 22" from the center of each pivot point. The part # he gave me for the arm was LE72113922S. He mentioned they had 24 in stock, but was now obsolete.
The outside adapter plate is Pentograph part # 200241, this is for the "dry" plate. If yours has the washer squirter that come out of the middle of the adaper, the part # is 200242.
