Yamaha 350 year 2015
eppem
Trumbull, CT
Epp:
My 350's will be within a millimeter of a Marlin with 300's as far as fuel burn. They work less.
Stats:
3500-3900RPM 32-35MPH 1.3-1.4MPG
4000-4200RPM 36-38MPH 1.3MPG
The above numbers are my normal-to-hi end cruise.
Once I've burned off several hundred lbs. of fuel, I'll get 1.5 at 3500-3600 RPM. During the infrequent times I run short bursts above 4300, I stop looking at the numbers as it gives me a rash....
It's all perspective, but I don't think the 350's are guzzlers. Before Grady discontinued the 350's as an option, the performance stats on their site had the 350's equal to or slightly ahead of the 300's in the mid-range RPM spectrum.
A side note..My contact at our Grady Club never got back to me regarding the history & past ownership of your Marlin. I didn't want you to think I just forgot about your question.
I am not knocking the 300 engines. Truth be told, they are probably a safer bet than the 350's in the "Big Picture" of ownership. To me, they are the perfect match for a Marlin and I'm thrilled with them.
My selling dealer tells me Yam is considering wrangling 350 HP out of the current 300 V6 block. Ok, fine, but you will lose the unmistakable torque and incredible power that only a V8 can provide. Without the extra two cylinders, it won't be much different than the current 300 except for 2-3 MPH on the hi end. V8's rock like Eric Clapton... My Marlin planes like a RIB inflatable by just feathering the throttles. I smile every time I do it.
A final note:
1.)TUKK66:
Good luck going forward.
2.) Happy Holidays to everyone here.
All good, I will share some numbers once the new engines are installed. As for burning off fuel for better efficiency, we pretty much just run off the forward tank for fishing and cruising around the Long Island Sound. Every now and then, dump 20-40 gallons in the back tank to keep lines clean. If needed, for long offshore runs, then we fill both tanks. In the off season, we keep the back tank empty and just fill the front tank, never an issue.
Thanks for the info. I asked about the pan because I have seen corroded ones that looked worse than the exhaust parts.. The oil pump is a tad expensive but doing it at the same time as the exhaust will be a lot less expensive than having to do it later.
mr_mbuna
I get 2 MPG at cruise (16 GPH at 32 MPH) on my Freedom 275 with a F350.
My F350 is an "A" model with nearly 800 hours and running strong.
I need to look into this Nizpro tune...
