Yamaha Ox66 225 charging problem
After some confusion and consternation with battery switches on my new to me 265 Express...
concluded that Port engine was not charging battery.
Measuring aux charging wire got ~ 0V dc.
Measuring 3 green wires on stator got 0V ac
Measuring resistance of stator between all 3 green wires infinite ohms.
36mm socket wrench- $20 AutoZone
Bolt-type wheel puller- $14 Harbor Freight
18" by 1/2" breaker bar wrench - $10 Harbor freight
Pulled flywheel and yes ..stator has broken wires.
Debated used on ebay $140 or new at Boats.net $593...went with new.
Waiting for part...
Wow. That is expensive. They don't even kiss you...
Sparkdog118
Ft Myers, fl
I know they are expensive. The 2 Orange posts are the ones that create the electricity to charge the battery and the many brown posts create the electricity for the ignition coils. New was the correct choice.
I would think that the 'charging' voltage with the motors running ( and the bank charger off) would have been looked at. The open coil would not generate and charging voltage and current.
