2000 272 Sailfish Motor Size
I'm not sure where you're getting that information from as a quick look at the brochure, I just picked a random year of 2005, shows the dry weight of the 270 Islander at 5,600 lbs and the dry weight of the 282 Sailfish at 5,800 lbs. Which is obviously only a difference of merely 200 lbs dry, which isn't going to be that big or noticeable at all.
I looked at the brochure from 2000. It appears that in 2005, its final year, the Islander gained almost 1000 pounds. No idea if it did, or it was a misprint. Find it hard to believe additional equipment weighed that much.
WRT to a four stroke 200 HP, I think it will move the boat fine; she won't be a speed demon, but isn't with 225s. The one issue to test is how the hull carries the extra weight. You may need to add ballast upfront to level her out.
I believe HPDI Twin 200s were the pick back then. Get the lightest 200/225/250s you can is my advice.
same thing with the Chase. 3975 to 4843 pounds from 2005 to 2006. No major changes to the boat either (2000 the running surface was extended, in 2002 the console and live well were reconfigured). I asked grady about this, and not a lot of info regarding it. their best guess was that maybe the higher weight included a hard top, but had no real answer.
I'm not one to be a conspiracy theorists, but typically when a company is elusive about why something changes is indicative of a liability issue. I wonder if GW beefed up some hulls that were a little under built, but can't say that? Not that the earlier builds were defective, but maybe internal standards changed leading to another layer or 2 of glass being added after a certain manufacturing date - or I could be 100% wrong.
Imagine the internet shit storm if THT found out GW boats built before a specific date had less glass.
that would be A LOT of glass. also, the boats would sit noticeably lower in the water
They had to rework the transoms for the larger motors. I think they may have adjusted the drains on some models. Others likely close. You may be on to something. If they didn't fix the bang cap after all the complaints, I suspect there are others....
This is the performance with my ‘01 282 with 4 cylinder F200’s. This is 220 gal of fuel and 5 adults from the surveyor report.
I had this thought that I knew was highly unlikely. But perhaps someone had a positive experience with repowering a Sailfish with the newer 4 cyl. 200 hp four strokes. I was hoping against hope.
I'm looking at repowering not too far down the road and it would be nice to get all these new digital accoutrements. Such discussions with the Admiral always seem to lead to discussions of furniture.
So I thought the (presumably) lower cost of the 200's would make the discussions go a bit better.
Repowering with the fully digital F250's is darn expensive. I'd have to hold out for the reportedly coming recession to even have a chance. Assuming I have any income in the recession!.
Rob
Reactions: wahoo33417
For 2000 GW replaced the 268 Islander with the 270 Islander. Biggest difference was the 268 had a Euro transom that stopped the hull short of the motors by about 24". The 270 has a full length hull all the way back to the transom. This was done to add more flotation to deal with the new 4-stroke engines.There were other smaller mods. Not sure I buy 1,000 lbs.
I have F150's on my 268. Previous owner re-powerd it. Could have gone to F200's or F225's inline 4-cylinder all about the same weight. The boat runs well. Switched to 4-blade props - game changing improvement in mid-range.
For 2000 GW replaced the 268 Islander with the 270 Islander. Biggest difference was the 268 had a Euro transom that stopped the hull short of the motors by about 24". The 270 has a full length hull all the way back to the transom. This was done to add more flotation to deal with the new 4-strok engines.There were other smaller mods. Not sure I buy 1,000 lbs.
That is incorrect. The Grady White 268 Islander, per the brochures, appears to have run until 2001 and it wasn't until the 2002 season that GW replaced the 268 Islander with the 270 Islander. Although, even after they did do the rebranding, the specs on the 268/270 Islander remained the same until its final year of 2005, when the weight of the boat for some reason went up 1k lbs. I think that the most reasonable explanation for the weight gain, besides it being a long winter, is because of a typo. Considering that the 265 Express has a similar length, yet has a wider beam and a wider transom width compared to the 270 Islander, but somehow the 270 Islander is still "200 lbs heavier" than the 265 Express? Again that doesn't make any sense to me, nor does it make any sense that a boat manufacturer like GW being as "cost effective" as they've been known to be, would make that many radical changes to a model of boat for only one year. Especially for a boat that they likely realized was going to be discontinued soon.
You left out the part about the 2002 270 looking identical to the older ones, except they had the full length hull.;)
I can also tell you from first hand experience, the 2005 270 specified hull weight is legit. I also thought of another reason the hull weight went up. I'll just say it goes back to my previous hunch, but for different reasons.
Reactions: Hookup1
Thank you! The hull running surface being lengthened to the transom was the important point. GW did the same thing with the Sailfish hull around that time. All to support the new 4-stroke motors.
I didn't have time to check but I wonder if they increased horsepower ratings and beefed the hull/transom up at that time?
From archive. GW definitely increased HP.
1995 268 400HP 4660 lbs - GW penciled in a correction from 4200 lbs to 4660.
1996 268 400HP 4660 lbs
1997 268 400HP 4660 lbs
1998 268 400HP 4660 lbs
1999 268 450HP 4660 lbs
2000 268 500HP 4660 lbs
2001 268 500HP 4660 lbs
2002 270 500HP 4660 lbs - I'm suspicious of the weight. It should have gone up at least a little
2003 270 500HP 4660 lbs
2004 270 500HP 4660 lbs
2005 270 500HP 5594 lbs
I'm not exactly sure as to what you're trying to say about the full length hull, as the 2001 268 Islander looks like the 2002 270 Islander to me. Are you trying to say that the overall length of the 2002 and newer Islander's is longer than the older ones or something? Also, what are you basing your "first hand experience" of a 2005 270 Islander off of, your 1999 248 Voyager?
Ok... but the specs on the boats have basically been the exact same throughout the years, with a few minor exceptions like a slightly taller hardtop starting in 2001 and a slightly different hull draft starting in 2004. In 2004 and 2005 they also list the overall length of the boat with a bow pulpit on it, of which they're also identical to one another, yet somehow the 2005 model mysteriously went up 1k lbs when everything else about it on paper is identical to the 2004 model? In regards to standard and optional features on the two boats, they're all the same between the 2004 and the 2005, except the 2005 comes standard with 8 drink holders and not 6 like the 2004. Then there are two optional features that are slightly different between the years... the 2005 had an option for Sirius satellite radio whereas the 2004 did not, and the 2005 had a 6 rod rack storage option in the cabin, whereas the 2004 only had a 4. Which I can't imagine that those extra 2 drink holders, satellite radio and a slightly larger rod rack holder add anywhere near an extra 1k lbs in weight to the boat :D
1995 268 8'6" beam BC w/Hardtop 8'9" Centerline length 26'11" Hull draft 15" Transom width 7'10" Weight w/o engine 4,660 lbs
1996 268 8'6" beam BC w/Hardtop 8'9" Centerline length 26'11" Hull draft 15" Transom width 7'10" Weight w/o engine 4,660 lbs
1997 268 8'6" beam BC w/Hardtop 8'9" Centerline length 26'11" Hull draft 15" Transom width 7'10" Weight w/o engine 4,660 lbs
1998 268 8'6" beam BC w/Hardtop 8'9" Centerline length 26'11" Hull draft 15" Transom width 7'10" Weight w/o engine 4,660 lbs
1999 268 8'6" beam BC w/Hardtop 8'9" Centerline length 26'11" Hull draft 15" Transom width 7'10" Weight w/o engine 4,660 lbs
2000 268 8'6" beam BC w/Hardtop 8'9" Centerline length 26'11" Hull draft 15" Transom width 7'10" Weight w/o engine 4,660 lbs
2001 268 8'6" beam BC w/Hardtop 9'3" Centerline length 26'11" Hull draft 15" Transom width 7'10" Weight w/o engine 4,660 lbs
2002 270 8'6" beam BC w/Hardtop 8'9" Centerline length 26'11" Hull draft 15" Transom width 7'10" Weight w/o engine 4,660 lbs
2003 270 8'6" beam BC w/Hardtop 8'9" Centerline length 26'11" Hull draft 15" Transom width 7'10" Weight w/o engine 4,660 lbs
2004 270 8'6" beam BC w/Hardtop 8'9" Centerline length 26'11" Hull draft 17" Transom width 7'10" Weight w/o engine 4,660 lbs LOA w/pulpit 29'4"
2005 270 8'6" beam BC w/Hardtop 8'9" Centerline length 26'11" Hull draft 17" Transom width 7'10" Weight w/o engine 5,594 lbs LOA w/pulpit 29'4"
First of all I have a 1997 268 GW Islander. I have a friend with a 2002 270 Islander. I think that qualifies as "first hand experience".
If you look at the hull (my hull!) below the GW "W" you can see a notch and then the hull angles up to the transom. Trim tabs are at the end of the running surface as well as the drain plug. This is a Euro transom. It functions like a bracket - puts the engine and props about 24" back in cleaner water for improved performance.
This hull is a 270 Islander hull. The running surface extends to the transom. Trim tabs and drain plug are on the transom. This design change added more flotation/support for the 4-stroke engines. The transom is larger (taller) and stronger.
GW did make some changes to the aft seating/battery box. I don't know if they really lengthened it the 4" but it's not important. GW changed the hull and the model number. They did the same thing with the Sailfish model around that time.
Look I'm not sure what you are trying to prove. The 268 and the 270 have slightly different hulls but not 1000 lbs and only on the 2005 model. My guess is the hull weights may not be correct in the advertising! Holly crap what a mistake! If it bothers you that much call GW customer service.
Uh, I own one. :)
Reactions: Hookup1
Umm... that was my point, as I've stated several times above.
Ok... while there may have been "some changes" made to the hulls over the years, my main point was that the specs per the brochures are relatively all the same, except for the 1k lb increase between 2004 and 2005 model years. Which was also mentioned above. My neighbor has a 2005 GW 270 Islander, that doesn't make me an expert on them, nor would I really say that makes it so I have "first hand experience". But I can read a brochure and use a bit of deductive reasoning and common sense to say that the weights are likely not accurate.
