richie rich said:
CJ, why would they need a an EPA variance? Both polyester and vinyl ester are dissolved in styrene and use MEKP....and unless they are going over an emissions limit due to higher production why would the EPA care? With all those boat builders in NC of which many use VE, GW would be the ones limited by the EPA? Plus many VE's are MACT compliant, passing EPA minimum standards for emissions.....I work with EPA/DEP regs in regards to emission limits....if we went to the State and said we needed to switch chemistry in order to compete and keep jobs local, they would find a way for us to do it.....it just doesn't sound right but maybe there's more to this than I'm understanding....
Maybe I just missed the meaning of the variance that allowed them to spray a very limited amount of vinylesters. I'll see if I can find it again.
If that's the case, then I'm not sure why they wouldn't go that way, especially for the larger hulls that would obviously wet-store.
I was doing research when we were talking about barrier coats before bottom paint on new hulls.
________________________________________________________
EDIT: Okay, I think this is the EPA permit I found on their gel-coat resin limits. It is a 2005 draft, so I don't even know if it's valid or not.
If you look on page 11, section d/iii you'll find that they are limited to 5% of all resin production to be vinylester resins.
http://daq.state.nc.us/permits/draft_pe ... 192005.pdf
I don't know for sure if this is a limiting factor or not for them, I just made that assumption when I ran across this data. I've been known to jump to conclusions with limited information. If anyone can shed more light on the subject I'm sure we would all be interested.
EDIT-2: Here is the 2007 final permit letter from the state of NC for Grady White Boats. It is quite clear that vinylester resins cannot comprise more than 5% of their resin applications. However it does say that it does not limit a
blend of vinylester and polyester resins for spray-on gel coat.
http://daq.state.nc.us/permits/TV_permits/Grady_t09.pdf
I also found some boat reports saying that the new Chesapeak has a blended polyester-vinylester gelcoat on the bottom surfaces.
Hmmm...so there you go. Still not sure what it all means, but there's some reading for anyone that's interested.
