- Jul 6, 2012
- Age
- 75
- Seafarer
Does the 265 have a piece of tubing where the top of the ANNIN attaches, or did you add something there?
I am about to add a led 10 inch bar to my pulpit what brand did you use do you have pictures and where did you run the wire for the switch?I also run at night and the way the bow rail reflects light it kills visibility. I just installed a high power LED bar light under my pulpit, the test fit was promising but didn't have a chance to use it on the water last weekend.
just did this with my 330. the front 3 are hard my center flips up in also and it is amazing and easy to open and close. you will find you dont need it open to run at night. the visibility i have thru the new hard pieces is better than the glass. good luck with it.I went with off white stamoid with "ANNIN" brand hard plastic, wrapping from vent window to vent window. No smiley or frowny windows. Center windshield flips up to Hardtop.
Sides are one piece and don't roll up. Rear center "door" can roll or flip up to hardtop ceiling. Gioia Sails, Lakewood, NJ
Here's a teaser picture. (film has not been peeled off the front plastic in the pic). It is awesome. Hard front is awesome. White was the right choice. Changes evrything.
Don't want to take pix til I finish my dash project & clean things up.
https://www.greatgrady.com/threads/led-spreader-lights-recommendations.24918/post-156383I am about to add a led 10 inch bar to my pulpit what brand did you use do you have pictures and where did you run the wire for the switch?
love the three position switch idea I am going to do that what light did you use and did you mount under pulpit or on. looks like under in that pic. I was thinking of going on top all the way out at the end
Under and back far enough from anchor...used existing screws . I use cheap led spreaders from eBay.4 for $24 Work great only issue with non stainless bracketslove the three position switch idea I am going to do that what light did you use and did you mount under pulpit or on. looks like under in that pic. I was thinking of going on top all the way out at the end
like makrolonWhen you say "ANNIN" hard plastic I can't find that brand. Is it a coated acrylic or a Makrolon/Lexan?
Oh I'm sorry its ANINA... it might be that the canvas shop is self-branding it?Maybe AIN Plastic, out of Norfolk?
https://gioiasails.com/home/gallery_anina.php
