They all say to run directly to the battery with the supplied cable. That's the only way they can know that you have the correct size wire and fuse and don't have wiring problems not related to their equipment. So when you call their tech support they are troubleshooting their equipment not your boat. Nobody wires them all to the battery of course because you would have a birds nest of wires all running to battery terminals. But, the first troubleshooting step is...connect it directly to the battery(including an inline fuse).
I don't suspect that the problem is just the A60.
You have low voltage at the fuse panel and the A60 is telling you that.
It can be one or more of several things.
It can be weak batteries that don't hold a charge.
It can be that the motor is not charging them properly.
It can be a poor connection of the "House" positive or negative wiring. This could be at the battery or battery switch or at the fuse panel.
It can be one of those wires corroded internally.
It can be poor connections or corroded battery switch.
Thanks for the thorough response...Responded to your questions below.
1. You recently replaced the starter and a battery. So you were having problems starting the motor?
Yes, starter ended up going. I would start and would churn but didn't seem to engage. I could get the engine to start by spraying WD-40 in the starter and tapping it with a hammer. It would turn over and then continuously start for the rest of that trip. I got tired of doing that, brought to the Marina that I use for Service and they replaced free of charge.
At the start of the season, 1 battery (2 yrs old) was replaced due to a stupid error. Long story short, the crossover between the two batteries was not connected. I didn't see this and just bought a new battery as the old one was dead when I got it and didn't want to bother with it after I got it back working only to encounter another issue with it, which was a result of the crossover being disconnected..
2. From what I can gather, you don't have any problem starting the motor. Is that correct?
It cranks and starts quickly? Yes. Little different behavior than in the past. I turn the key, slight delay (less than a second), would churn for another second and then kick over. Every time it starts with no issue.
3. The motor maintains the batteries and you have not had to recharge the batteries with a charger?
Nope, so far so good.
4. When your motor is running, what voltage does the yamaha gauge read? and the other electronics, do they have volt readouts? With
motor running the readouts are all over 12.8 v and
close to 14V?
Pretty sure it was either 13.7 or 14.3V when I last looked. I'll double check the next time I use it but definitely over 12.7.
5. When you turn all the electronics off does the voltage go up?
I have not tried this yet, but will the next time I am out.
6. You have two batteries and presumably a 1-2-both-off switch, yes? You have the same problem with each battery selected?
Yes to all.
7. Confirm, you are not using the Both setting to start the motor? You have one new battery and an older one.The problem occurs even on the new one?
Not using the both when starting. I have the same issue when using the old one (2 years or less old) and new one (2 - 3 months)
8. You have the typical grady setup of a 40 Amp red button breaker near the batteries that feeds the dash thru 6 gauge wire?
Pretty sure its a 40amp red button, definitely a red button breaker next to the battery switch. As for the 6 gauge, I believe so, but I need to revisit the wiring. The wiring diagram (attached) shows 10AMP by the batteries running to the front and then a 6gauge wiring coming out. Not following this at all so I need to inspect. Think I saw in accessory panel spec that it could be a 6 gauge or 10 gauge.
9. Have you physically traced out all of the connections and wires. Back off the nuts and re-tighten. Look for" green" and look for hard spots in wire that indicate internal corrosion. Pull the battery switch off the bulkhead and look at and tighen the connections. That is the first step. I would't go replacing starters and batteries first.
Not yet, but started looking at the helm where the wires are all running to. There is definitely some corrosion/ "green" happening there. Also noticed that some nuts were loose and I quickly tightened by hand. I'll spend more time here the next time I am on it.
10. I don't know your experience or comfort level with these things.
Definitely lack experience with DC with my first experience being a couple months ago when I replaced the front bilge pump and switch, learning how they all operate in the process. I'm good with wiring and fixing electrical issues in my house, but never did much with DC. I built computers when I was a kid, so understand how things work.
No concerns from a comfort level, but the biggest concern I have is that its a 20 year old boat with history so who knows what was done to circumvent prior issues rather than address them. I just need to figure out how the wires are running. I agree with using the jumper to root cause the issue as it eliminates most variables
I like learning how things work and can lose myself hours doing it, so that should help
