- Sep 16, 2019
- Age
- 41
- Bayville, New Jersey
- Seafarer
The bottom right corner of the fuse block is a negative bus. what feeds that? Is it a jumper from the negative bus in the other picture or does the neg from the battery go there?
Is it fed with the same gauge wire as the positive?
https://www.greatgrady.com/attachments/22677be9-1d96-49a1-8673-324bb4631057-jpeg.14780/
Those blue green wires are fuel tank & bilge pump grounds
I'll double check both. I believe the negative on the fuse just goes to the negative bus, but will confirm that.
Were consolidated negative bus and fuse not around in the early 2000s? I am looking at buying a new fuse panel and was curious if I should replace both (negative bus as well) or just the fuse panel. If replacing both, should I just buy an integrated one that includes all of the negatives. I reached out to Grady this morning to see what they use on their new boats.
