PointedRose
- Feb 11, 2021
- San Francisco
- Overnighter
You guys are right, there is a lot more weight back there with dual 200s. I don't have any problem with you big boys have to do. I should have made it more clear that it was for my (much lighter) boat, I can get the job done fine with just the engine.
Keitha, I have played around with watch MPG as a mess with stuff, but only with engine trim. I lose about .1MPG with the engine all the forward, I'll have to take your advice and see if I can make it better. Coming in at about 32mph I believe I'm right around 2.5mpg (which is way less than what Grady says you will get but I'm in Pacific slop, I bet they do those performance tests on glass flat surfaces).
Lucky,
I would say next time you're out while cruising: try dropping your trim tabs (assuming you have the Bennet tab gauge) one light on each side, then see how it reacts to motor trim changes.
I can say my boat agrees. I can get it down there but it wants to go faster.BTW...NO Grady wants to go 20mph.
The other difference you'll find is that the boat slams you way less in waves.Great advice! So, I ran this weekend with no trim tabs, and just used the motors to trim the boat. Huuuuge difference.
I was able to plane at 19 knots in some slop at 3600rpm and hold it, with the motors on the second lowest trim setting. Trimming up further (bow up) knocked me off plane, and trimming them lower increased speed but made the ride squirrelly. At the 19knot/3600 setting, I was burning about 14gph. In statue miles, a little over 1.5mpg. I'm sure I can fine tune this more, but I'm pretty happy with this outcome.
Thanks to all for the excellent advice about using motor trim instead of tabs.
Sounds like you're at a good starting point with the motor trim; make note of the angle from your gauges and use that as a baseline for using the tabs your next time out. Repeat the process using only the trim tabs (leave engines as best setting from this past weekend) and see if you can get an improvement in the efficiency/planing speed/ride quality. Ultimately you'll likely have to adjust your motor trim from the "past weeked" position to find the best efficiency point for the hull but that's all part of learning the specific vessel.Great advice! So, I ran this weekend with no trim tabs, and just used the motors to trim the boat. Huuuuge difference.
Keep in mind that the best engine/tab settings will also vary with the ocean conditions and hull load/distribution. There's a lot of really good general advice but you'll eventually find out what works best for your specific boat. Best of luck to you on dialing in your new boat!
I think my boat must be weird. I can move the bow up and down about 3 feet with absolutely no trim tabs in the mix. I've never wanted to push the bow down more than I can with the engine. I use the tabs but only to correct list. I basically do what the techy guy from Grady says to do when driving a boat like mine. I did switch to a 4 blade prop, it didn't make a lot of difference, some, not a lot.When you boat is balanced, it will react to motor trim a lot quicker and more sensitive.
Luckydude,I think my boat must be weird. I can move the bow up and down about 3 feet with absolutely no trim tabs in the mix. I've never wanted to push the bow down more than I can with the engine. I use the tabs but only to correct list. I basically do what the techy guy from Grady says to do when driving a boat like mine. I did switch to a 4 blade prop, it didn't make a lot of difference, some, not a lot.
I get that people with heavier sterns would do what I do. I like what I do because I've got more experience (what little I have) getting things right with the motor. I just have some sort of mental model where that works for me. The trim tabs, mainly because I can't see the red indicators that tell you where they are (I'm red color blind), always feel like I'm not sure where they are. So I'm reluctant to use them (yes, I'm weird, that's well established). But I have a system that gets the job done for me, at least for the time being. I'm really not trying to rude or not listen to your advice, I'm trying to have the least number of moving parts that gets the job done. On the 228, the engine will get 'er done.
I suspect, as I gain more experience, in more kinds of seas, I'll come crawling back with my tail between my legs and say "OK, I'm ready to learn about trim tabs"So thanks for all this, I may mine it later.
Luckydude,
I mean this with all due respect, but do want to help control misinformation.
OK, Now I'm understanding you better. I only comment because I feel that you are giving (not the best) advice based on limited experience. I don't care if people listen to me or not, I am genuinely glad you have a system that works for you.
I feel that you are giving "advice" though that is a bit missguided. For example: You state that trim tabs are not needed or effective on "small boats with single motors" and that the Gulfstreams need them because they are bigger. This is just not accurate. You may have a solution that works for you and that is Great, but general use of Trim Tabs/Engine Trim would still be effective and probably the best way to run the boats - these are time tested across many boat platforms.
Grady White spent the money to put Trim Tabs on the boat for a reason. Like I said before, Trim Tabs and Engine trim do different things. Just because you can't see the trim indicator and chose not to use them, does not mean they are ineffective on small boats.
It takes a lot of time on the water to get to really know the feel of a boat and what it should feel like when trimmed well.
My only complaint about the trim tabs on the Gulfstream is I wish they were a size bigger.
