Leaving home for moorage
Thanks Magic, I have four months to find a "gorgeous" bottom paint, before it get slipped.
Reactions: magicalbill
bottom paint is a must or you will likely do damage to the hull with the scrapping needed to remove the barnacles and sanding to remove the husks left behind. My last boat was a 23 mako and was on a mooring from may-oct for the last 25 years
Thank you all for your ongoing input, Kietha, probably won't go with the hull liner but a good idea. Yes I like the idea of a white bottom paint, and just may go that route. Do not have an issue with barnacle in this cold water marina, but no doubt there sill be a lawn to cut on the underside.
