looks like for the prop shaft need two seals and two orings.. anything else in there i should have onhand just in case ?? I need to order these today..
Not that I know of. I clean the main o ring surface and groove with wire wheel. emery cloth the flat surface of the carrier that touches the housing.
Gonna be a little tougher since the prop shaft is in the unit to clean the inside of the housing. It is an option to remove the shift shaft if you need room to get your hand in the housing to clean the area that the o rings seat. When you pull up the shift shaft, the prop shaft pulls right out. If you do go that far, it is a good idea to emery out the shift slide cavity behind the forward gear. Has a habit of hanging up sometimes. If you emery out a few thousands it shifts smoother and prevents wear on the clutch. Just replaced a clutch because of this problem today on a F350.Customer was lucky. The reverse gear almost didn’t survive.
If you zoom in on the clutch teeth, this is from jamming just a hand full of times. Dealer said he needed a 3000 dollar Fly by wire Shift actuator since it was jamming in reverse. I wasn’t buying that explanation. Pulled lower apart and that is what I found. Glad he didn’t buy an actuator n find out he needed a lower rebuild.
True. Not a big job if you haven’t put the pump on it yet. The o ring will definitely survive with a nice bead of 847. Just make sure you emery cloth the inside of the housing to bare metal. And rinse it out with brake cleaner.
It's not a big job. The pump is not on yet. I emailed you about item 21 on the drwg the prop shaft roller bearing. The book says not reusable. Is that true.
Lower is back in. Vacuum test was perfect all new seals and orings..want to say Thanks to everyone
for their help.. Especially Sparkdog for his emails and pm's...Great guy and was a bunch of help.
