Small change in plans. I decided to move the ring terminal located on the battery for that unswitched power in the overhead console to the house battery switch. That will make that power switched on the house side. Then I located where those wire are running through the chase and up under the dash. I then cut and routed those wires to run up to the console on the dash and will use them to power a new fuse block to run my electronics. Those wires are pretty hefty (I’m guessing 10 or 12 AWG) and I thought it would be a good idea to put all my Garmin equipment (MFD and Radome) on the same dedicated run to the battery (except for the fuel flow sensors). Anyone see any issue with getting my power this way?
Also, there are a few things I may want to access in the future on the back of the Garmin MFD. USB port, HDMI port and SD card slot. It would be nice to be able to access these without having to break the seal on the dash. A while back I replaced my cockpit and transom pop out inspection ports with screw in style. I think they are a little more secure, but I still have my old inspection ports. I was thinking of making a cutout in the bottom of the console and installing one of the inspection ports from the underside. I could then access the back of the MFD simply by removing one of the panels in the head. Anyone done anything like this or have thoughts? Would there ever really be a need to access the SD card? Generally, I will always have WiFi connectivity. I still need to transfer my waypoints from my old GPSMap to this new unit but will be a onetime deal.
