richie rich
What Brian mentioned will work if you have some grid left up front and you have any markings at all on the hull....you can take measurments or snap a chaulk line .....based on your picture you still have tabbing left on the hull...thats all you need.....take a plumb bob and hang it under the fishbox area untill the tip hits the tab marks...make a mark at the bow, the fishbox and at the transom and you have a 3 point straight line. I believe that hull is a 20 degree deadrise from midship back, so double check the angle, cut a test piece and set the piece on the tab mark and see how it lines up with the plumb bob mark under the fish box...should be flush and perpendicular.
to replicate the 1/4 inch drop and fill of resin/matt....once the stringer is in, if there are any short falls or inconsistencies, run a 1 inch strip of wood along the top sides of the new stringer and make sure they touch the underside of the fishbox. Temporarily use screws to hold them...fit your deck and check for level......then before final deck replacement just use thickened epoxy to fill in the gaps and make a bed for bonding the deck.
PS ...Grinding glass is fun......NOT :shock:
