I can take a peak at the gas in the filters but I think the gas is getting through just fine since I was burning 40 GPH during the wide open throttle test.Compression is fine.
Dump the fuel filters into a clear jar (one for each filter). Let it sit for an hour and then inspect and post pics.
I assume your engine has some type of VST tank with a hi-pressure pump inside? Inspect the inside of the tank and, likely, some type of filter on the hi-pressure pump.
Pull the plugs and inspect.
Monitor fuel pressure while running.
For good measure... take a run with the fuel cap off.
Isn't the change is prop-slip percentage from 5% to 36% i smoking gun of sorts? If I think of a car analogy, prop slipping is like tires screeching rubber which is usually a sign of a healthy car engine. The prop-slip percentage change would seem to indicate a problem with the hull or the props and there is no visible damage to the SS props.
