- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
I know it may be a pain but if it were me I would...
pull the #2 battery and connect it directly to the start cables of the motor with nothing else in the circuit.
If it works fine (probably will) then its cables or switch
Connect #2 batt back. Test it again. Still broke?
Bypass the switch in #2 position with a jumper cable. If it works then its the switch that is the problem
If not then its a connection or cable. Loosen and re-tighten all conections if not already done.
Use a jumper cable from the #2 Neg to the #1 neg.
use jumper cable from Batt#2 pos to #2 on switch
