- Oct 12, 2017
- Manasquan Inlet NJ
- Website
- www.youtube.com
- Express 265
I've been an electronics guy since 1979. I've been a teenage TV repairman. I've worked on navy gun & missle firecontrol systems. I've been a field service engineer and later a national service manager for medical diagnostic systems. I've trained tech support to troubleshoot over the phone.
Troubleshooting thru text over multiple weeks is very difficult but I will try to help
I do not know what is causing the problem. I don't know if you are missing an important symptom that has us looking in the wrong place.
in troubleshooting, much like spotting naval gunfire, there are three methods...Bracket, Ladder, and "Hunt & Peck"
You seem to be in Hunt & Peck. Thats the least effective method. Sometimes you get lucky based on a guess or knowledge of a common problem. You didn't get lucky.
At this point you will learn something by removing battery#2 from the boat, connecting the start cable from the motor directly to the positive and negative battery terminals with no other components in the circiut. If it works repeatedly then you have ruled out the battery, the motor's cables, and the motor.
From there I would use the ladder method and work in one direction, one piece at a time. from the motor thru your cabling and switches to the battery (when its in its normal position)
There is a Black Neg wire from Batt1 to batt2. I have not yet heard mention of you removing or jumping that.
Your first step in the ladder is connecting the neg of the motor cable to batt1 and using the existing neg batt1/Batt2 jumper. Then connect the pos coming directly from the motor to pos Batt2(bypass the switch). This step of the ladder tests the neg jumper from batt1 to batt2.
As you work your way thru cables (both pos & neg) look for bad connections and bad wires. Wires can be green inside and look fine from the outside. Flex them and feel for hard spots.
The bad wire can measure near 0 ohms on a meter and still drop too much voltage or fail to conduct enough current when cranking the starter.
If you have the problem, use a jumper cable to bypass the suspected cable.
