richie rich
Going back on the thread, page one shows the fishbox and toe rail...there should be a seam along the fishbox so cut the caulked seam......then cut across the toerail where the trim normally is...at least on my sailfish.....on center of the trim so you can add the backing strip and cover the finished joint with the trim.....then if you look on page 2, second to the last picture you see the rear engine well area/bulkhead.....I would leave a connecting strip of the original deck right at the fuel deck lid, lip area, and cut back to the toe rail......this will leave a connection all the way across the deck and give you a place to put a backing strip under the repaired deck lid....would like to see a better picture of that rear area to see where to cut.
PS...try and ask to speak with Dan Naugle at GW...he is their structural engineer and that's who I spoke with last year.
