Yep. Backup AC power from Inverter/charger with multiple battery banks is very common.. Seems like plenty of campers are already doing this.
Yes, and from what I see, using an "Inverter Microwave" might be useful. Lower, more consistent draw possible. What suprises me is how much a Keurig draws.when sizing the inverter be sure to use surge current draw as your basis, not running. some items really pull at the start, ie fridge compressor
That looks interesting. Could charge from shore power.This looks like the easy solution!
https://www.jackery.com/products/ex..._content=sag_organic&utm_campaign=sag_organic
dakotalithium.com
Ok...so if you reheat leftovers for lunch on your boat using this system, by the 100th meal the system paid for itself! Does that help? lolThe Jackery one is solar capable too, just plug in their panels. and it can charge (slowly) thru a12V accessory. They make a 2kW version.
It can pretty much replace a little Honda gas generator at slightly higher price and no issues with fuel. Portable. Can store it in cabin. No wiring.
I just can't spend $1500 for coffee and I already have a big portable generator for home so I can't use it for other uses.
So I am right there with you. If I buy the boat without the gen I am considering the same approach. I am looking at 24v, simply for the efficiency and safety...less amperage, less heat, better conversion of energy. But the extra cost might not be worth it. I would probably go with lithium, more usable energy, lighter, faster recharge. My plan would be to charge via AC through the inverter/charger at the dock. Some day I could consider a solar panel or or victron/xantrax DC/DC charging from the motor, or simply add a second battery if I am pleased with the system. But I think dockside AC charging will be much faster and easier, and keep the system simple. With 24v 100ah lithium (or 12v 200ah), it should meet my power needs. I will also keep my system separate from my house.I'll post a full write up with pictures once the system is installed, but just FYI, here's my thinking and some rough math.
BTW...yah...charging Lithium directly from engine is no bueno. None of the LifePo4 manufacture recommend that.. Must come through a dc/dc charger. Needs to be precise voltage and well regulated. Look at the solar panels sold by Dakota, they look interesting. Could keep you charged at the mooring. I might wind up with a panel and a dc/dc charger. I will determine that later. For now an inverter/charger and a lithium battery.I considered going Lithium Ion which would enable me to downsize to only 100 amp hours of total capacity (since you can use up pretty much the full capacity without harm), but I decided to stay Lead Acid because I wanted to be able to use the Aux charging ports from my Yamaha 4.2L outboards to charge the inverter battery bank when underway. I spend 1 month each summer on a mooring in Nantucket away from any shore power, so my engines are my only charging source. I've read highly mixed opinions about charging Lion batteries directly from outboards (risk of burning out the alternators), and Yamaha is pretty clear that they do not recommend. Plus, with the aux cables connected, the outboards will supply some of the amperage needed to run the inverter.
Yeah I would have definitely gone Lithium and dockside AC charging if I didn't spend that month away from my dock. But ironically that's also when I'm most likely to be using the inverter!...I think dockside AC charging will be much faster and easier, and keep the system simple. With 24v 100ah lithium (or 12v 200ah), it should meet my power needs. I will also keep my system separate from my house.
I am looking at some 2005 Marlin 300's. Some with, some without the Fisher Panda Generator.
I primarily want a gen for the handful of times I overnight offshore fish each year. But I am wondering if it would be wiser to simply use a portable Honda for those few times a year, as opposed to the extra weight and maintenance of a gen year round. Offshore, I am primarily interested in being able to run my electronics, lights and maybe the microwave/coffee maker. A/C offshore would not necessarily a must, but would use if I had a gen.
I was also wondering, are you able to run the microwave or coffee machine off the batteries with the engine running if you don't have a gen? Outside of offshore fishing, it would be nice to heat up some lunch and/or coffee when I am inshore fishing as well.
I use a Honda on my Marlin. It works great for the coffee maker, microwave, etcI am looking at some 2005 Marlin 300's. Some with, some without the Fisher Panda Generator.
Agreed. If I can find one with.If your shopping around, go for all the bells and whistles, generator, bow truster and AC. You will be kicking yourself for years if you don’t.
