- Jan 21, 2022
- Age
- 55
- Marlin
So...having spent a lot of time looking into this... I find the Jackery interesting, the Bluetti even more so, but there are plenty of issues.
1) the size. 72ah, not much.
2) keeping it ready and charged. apparently the chargers are not really designed for continuous charging.
3) I don't believe it would be grounded.
4) unitized...proprietary and less ability to upgrade/expand
I am leaning towards a Victron system. It's modular, it's safe, it has a built in transfer switch, I can use batteries up to 400ah and add more later, it handles more capacity, I can leaved plugged into shore power, it would be wired into my AC panel, the tech support, faster recharge times, more efficient power conversion, can add DC charging from my motor or even from solar panels...and to start, I can keep the cost not to much more than the jackery. If you get the system up to 12v 400a (24v 200ah) you have some SERIOUS amount of power available to you.I would probably start with 200ah. Add another if the system works the way I hope.
I would prefer a gen, but a simply battery, inverter/charger system sounds like a much safer, smarter way to go. If I do go this route, it will be under the supervision of an actual marine electrician. One of the hardest part is finding the optimal battery, I am leaning towards Renology or Battle Born. I would prefer to go 24v...seems safer and more efficient.
My assumption on the Jackery, it would plug into your shore power and function the same.
